Автор Тема: 09TV066R14  (Прочитано 572 раз)
09TV066R14
« : 19 Июня 2021, 06:59:13 »
09TV066R14
EX-2N_Peppermint_AVC Chassis
Subject: Software Packages Follow-Up for EX-2N_Peppermint_AVC Chassis [REVISION 14]
The latest software package #46 is valid for all “EX-2N_Peppermint with AVC chassis” models, and solves the
following issues.
Issue IRIS code Rev.
Channels lost, TXT not working, Country setting changed to UK (Spain, France) M727 R14
Occasionally picture and sound are activated at night
* When the TV wakes up for ASU (3:00 AM) or for OAD (5:00 AM) at night, picture and sound
sometimes appear.
217X R13
Problem with BBC MHEG when selecting services (UK)
* The TV crashes, freezes and reboots when the BBC MHEG application is used to select services
on the BBC interactive channel.
6286 R13
TV reboots with R6 MUX (France)
* Due to a change in the French broadcaster signal, when any service of M6 Mux is selected,
the TV freezes with only a banner displayed while the screen is dark. Next, the red LED
lights up and the TV switches off.
E11A R12
Incorrect EPG language selection (Greek)
* EPG language for MPEG4 channels appears in English instead of Greek. U721 R12
Teletext subtitles problem (France)
* The subtitles are permanently displayed. French accents are not correctly displayed. C286 R12
Inconsistent display of EPG data
* EPG data is not displayed for ‘cross carried’ services. Several channels show
“No Event Information”.
1286 R11
Subtitles in ARTE HD (DVB-T service) are not displayed (France) D732 R11
TV switches off and restarts by itself after 30 seconds (Iceland) 3722 R11
Picture squeeze vertically in half when changing AV inputs 6336 R11
Wrong EPG coding
* Some specific Polish characters have a wrong EPG coding. 1731 R11
Crash at Wehlo network (Finland)
* Due to a change in the signal at the Wehlo cable broadcaster in Finland, a set may crash
showing several symptoms, such as ‘blocked’, ‘no response to remote commander or buttons’,
or ‘automatic restart'.
D11F R11
TV hangs in Marseille (Numericable)
* Due to a change in broadcaster signal, the TV hangs up in Numericable network in
DVB-T services.
D11F R11
Real time subtitle Teletext does not work properly (Italy)
* The real time subtitles of Teletext are refreshed too quickly. 1286 R11
09TV066 - Software Packages Follow-Up for EX-2N_Peppermint_AVC Chassis [REVISION 14]
« Последнее редактирование: 01 Декабря 2023, 00:41:26 от aze1959 »
