Автор Тема: tv 37PFL5332/78 резервный светодиод выключен, мертвый источник  (Прочитано 559 раз)
eletmoraes
The source board or main board may be defective. Is it possible to test (run) a power supply without using the main board?
I only connected the power supply without using the main board and so far I only found the voltage of 5v on the pin + 5V2_TRF_A
the standby led is off, I only found voltage on the 5v C412 capacitor
serg-161
/Кин-дза-дза!/
