Автор Тема: ASC20181018001  (Прочитано 680 раз)
ASC20181018001
« : 09 Января 2021, 11:50:14 »
Wi-Fi Stops Working After Main Board is Replaced
PRODUCT:
LED TV
BULLETIN NUMBER:
ASC20181018001
CREATE DATE:
10/18/2018
REVISION DATE:
MODELS:
UN40MU6290FXZA, UN40MU629DFXZA, UN43MU6290FXZA, UN43MU629DFXZA
UN49MU6290FXZA, UN49MU629DFXZA, UN50MU6290FXZA, UN50MU629DFXZA
UN55MU6290FXZA, UN55MU629DFXZA, UN65MU6290FXZA, UN65MU629DFXZA
UN75MU6290FXZA, UN75MU629DFXZA, UN49MU6490FXZA, UN49MU649DFXZA
UN55MU6490FXZA, UN55MU649DFXZA, UN65MU6490FXZA, UN65MU649DFXZA
Important: Service tips are published for informational purposes only and are intended for use only by personnel qualified for the specific tasks depicted. The information contained in this service tip does not expand or otherwise alter Samsung’s standard limited warranty applicable to the product. This information is published for experienced repair technicians only and is not intended for use by the public. It does not contain warnings to advise non-technical individuals of possible dangers in attempting to service a product. Only experienced professional technicians should repair products powered by electricity. Any attempt to service or repair the product or products dealt with in this service tip by anyone else could result in serious injury or death. Information provided in this document is subject to change or update without notice.
SYMPTON:
After the main board is replaced, Wi-Fi may not work. The TV won’t see any Wi-Fi networks and the Wi-Fi MAC address fails.
CAUSE:
Two types of Wi-Fi modules were used in the listed models, BN59-01264A and BN59-01174D. During the first
phase of production, the BN59-01264A Wi-Fi module was used. Afterwards, the BN59-01174D Wi-Fi module
was used. The two parts are functionally compatible. The same TV model may use either version of the Wi-Fi
module. The part number is printed on the label of each Wi-Fi module for easy identification. The correct Wi-Fi
Vendor Option Byte Value must be used.
