Автор Тема: TPS51916 datasheet.  (Прочитано 703 раз)
serg-161
TPS51916 datasheet.
« : 02 Декабря 2020, 13:47:36 »
The TPS51916EVM-746 is designed to use a regulated 12-V bus to produce a regulated 1.5-VDDQ output at up to a 20-A load current. The TPS51916EVM-746 demonstrates TPS51916 in a typical DDR3 application with D-CAP2-mode operation. The EVM also provides test points to evaluate the performance of the TPS51916.
/Кин-дза-дза!/
