Автор Тема: SLCD-001  (Прочитано 833 раз)
SLCD-001
« : 21 Октября 2020, 20:35:18 »
General
Subject
Model
Note : For units with NEW Serial Number, there is additional (A) at the model label. Example : LC-39LE440M (A)
Firmware
Servicing
ensure to upgrade the firmware file to matched with the model name as mentioned in the table above.
Note: Kindly ensure to put only one file(firmware) in the USB per one time before firmware upgrade service.
Parts
Q'ty
Q'ty
1
1
BL
Nov2012
1
1
BC
Nov2012
Note
The default firmware in mainboard when purchasing service part is for 29" model.
Model
LC-29LE440M (A)
LC-39LE440M (A)
LC-29LE440M
LC-39LE440M
Same mainboard/component is used for both LC-29LE440M and LC-39LE440M.
Main Unit Assembly
Component on Main Unit
For firmware upgrade method, please refer to Service Manual. If you have replaced Mainboard for service, please be
Ref No.
MAIN UNIT, T.VST59.91A_V59
TSUMV59XE-Z1
U6
MAIN001
Description
9JDIN7J059XE0
NEW
9JD1564200021
9JDIN7J059XE1
OLD
Parts Code
We are to inform you about the changes of Mainboard
2115xxxxx ~
Additional features added for DivX/WMA/AAC/AC-3 function
Model
OLD Serial Number
Serial Number
2085xxxxx ~ 2105xxxxx
LC-39LE440M - P
2095xxxxx ~ 2105xxxxx
2115xxxxx ~
LC-39LE440M - J
2115xxxxx ~
C: Interchangeable from
Asia Service Technical Center
SHARP ELECTRONICS(M) MALAYSIA
Price code
Effective from
9JD1564200013
NEW Serial Number
LC-29LE440M - Z
LC-29LE440M - P
LC-29LE440M - N
2115xxxxx ~
2115xxxxx ~
2115xxxxx ~
2115xxxxx ~
LC-29LE440M - M
LC-39LE440M - Z
2115xxxxx ~
2115xxxxx ~
LC-39LE440M - M
B: Interchangeable from OLD to NEW
D: Not interchangeable
Interchangeability
A: Completely interchangeable
LC-39LE440M - N
