Автор Тема: SP054401X  (Прочитано 689 раз)
SP054401X
« : 21 Октября 2020, 19:15:06 »
IRIS Symptom Code: ---- IRIS Section: ----
1
A B C D
INTERCHANGEABLE From OLD to NEW From NEW to OLD NOT INTERCHANGEABLE
GENERAL
MODELS
SERIAL No.
INTERCHANGEABILITY
PARTS
SERVICING
It may appear different picture and / or sound effects as follows, cured with the same software
update:
1. Black square on screen when TV Set is switched on (problem for NULL string under some
conditions at switching on.)
2. TV set may switch off during program sorting process at random. Image muted by going up
or down one program in sorting feature and it can not be recovered. This means it should be
reset by Mains.
3. No sound, picture bending or fl ashing pictures (in case of high white contents) due to overmodulated
signals distributed via cable network in some areas of France (SECAM L System.)
When any of the above TV set is called for Service because the describe phenomenon, proceed
to update the IC1002 Software Version to GA6v0.9ExpF6 or upper.
See at the Service Manual “How to update VCTi Software” on page 29. This procedure will guide
a proper Flash Memory updating. Service Manual Code: SE00LC26GA600.
MODEL SERIAL
No. MODEL SERIAL
No. MODEL SERIAL
No.
LC-26GA6EE - LC-26GA6EF - LC-26GA6EI -
LC-26GA6EK - LC-26GA6ERU - LC-26BV6E -
LC-32GA6EE - LC-32GA6EF - LC-32GA6EI -
LC-32GA6EK - LC-32GA6ERU - LC-32BV6E -
LC-37GA6EE - LC-37GA6EF - LC-37GA6EI -
LC-37GA6EK - LC-37GA6ERU - -
