Автор Тема: SP061701X  (Прочитано 516 раз)
SP061701X
« : 21 Октября 2020, 19:07:25 »
IRIS Symptom Code: ---- IRIS Section: ----
A B C D
INTERCHANGEABLE From OLD to NEW From NEW to OLD NOT INTERCHANGEABLE
GENERAL
MODELS
SERIAL No.
INTERCHANGEABILITY
PARTS
SERVICING
Is possible that, in some TV sets, doesn’t appear picture in the screen because the IC3002 is
defective.
Inspection:
With TV set in ON condition, after a warm-up time, the screen is muted (black screen) by a malfunction
of the internal VCTP LVDS area. Cooling the TV set or the VCTP IC, the screen leaves
the mute state. Sometimes, it’s necessary to switch-on again the TV set to get a proper picture.
In this case proceed as follows:
Countermeasure
Replace the VCTP IC (IC3002 of Main PWB) for a new one. Please, use new VCTP B3 mask
instead old one B2.
1. B3 mask requirements:
1.1. Update the required VCTP Software Version File below detailed or upper, depending on the
model:
For P55 Series: “LEW05A-WPAL-V1202.bin”
For P70 Series: “LEW05A-WPAL-DTV_V1042.bin”
1.1.1 Select the inches TV Set at “QS Temperature NVM Data Confi rmation Adjustment”.
1.1.2. Select the country TV Set at “Factory Settings adjustment”.
MODEL MODEL MODEL MODEL MODEL MODEL
LC26P55EE LC32P55EE LC37P55EE LC26P70EE LC32P70EE LC37P70EE
LC26P55EF LC32P55EF LC37P55EF LC26P70EF LC32P70EF LC37P70EF
LC26P55EI LC32P55EI LC37P55EI LC26P70EI LC32P70EI LC37P70EI
LC26P55EK LC32P55EK LC37P55EK LC26P70EK LC32P70EK LC37P70EK
LC26P55ERU LC32P55ERU LC37P55ERU LC26P70ERU LC32P70ERU LC37P70ERU
