Автор Тема: SP061702X  (Прочитано 492 раз)
SP061702X
« : 21 Октября 2020, 19:06:36 »
IRIS Symptom Code: ---- IRIS Section: ----
A B C D
INTERCHANGEABLE From OLD to NEW From NEW to OLD NOT INTERCHANGEABLE
GENERAL
MODELS
SERIAL No.
INTERCHANGEABILITY
PARTS
SERVICING
Is possible that, in some TV sets, doesn’t appear picture in the screen because the IC3002 is
defective.
Inspection:
With TV set in ON condition, after a warm-up time, the screen is muted (black screen) by a malfunction
of the internal VCTP LVDS area. Cooling the TV set or the VCTP IC, the screen leaves
the mute state. Sometimes, it’s necessary to switch-on again the TV set to get a proper picture.
In this case proceed as follows:
Countermeasure
Replace the VCTP IC (IC3002 of Main PWB) for a new one. Please, use new VCTP B3 mask
instead old one B2.
1. B3 mask requirements:
1.1. Update the required VCTP Software Version File below detailed or upper, depending on the
model:
For GA9 Series: “LEW05A-WXGA-V1042.bin”
1.1.1 Select the inches TV Set at “QS Temperature NVM Data Confi rmation Adjustment”.
1.1.2. Select the country TV Set at “Factory Settings adjustment”.
MODEL MODEL MODEL MODEL MODEL MODEL
LC32GA9EE ------ LC37GA9EE ------ LC32BV9E ------
LC32GA9EF ------ LC37GA9EF ------ LC37BV9E ------
LC32GA9EI ------ LC37GA9EI ------ ------ ------
LC32GA9EK ------ LC37GA9EK ------ ------ ------
LC32GA9ERU ------ LC37GA9ERU
