Автор Тема: SP062301X  (Прочитано 477 раз)
SP062301X
« : 21 Октября 2020, 19:03:20 »
IRIS Symptom Code: ---- IRIS Section: ----
When any of the above mentioned models is called for Service with described phenomenon,
please apply this modifi cation in order to solve the problem:
- Update the VCTp software (Main PWB) following the GA-8 series First Edition Service Manual.
(See Page 23)
VCTp software version fi les: LEW05A_GA8_V1022Q for 32” / LEW05A_GA8_V1022S for 37”.
Is possible to see which VCTp software version is mounted at the TV on page 1/11 of Service
Adjustment Menu:
A B C D
INTERCHANGEABLE From OLD to NEW From NEW to OLD NOT INTERCHANGEABLE
GENERAL
MODELS
SERIAL No.
INTERCHANGEABILITY
PARTS
SERVICING
Switching off the TV set on EXT 4 or EXT 5, it is possible that after switch on again the TV set
remains muted, independently if it is started with the R/C, Main Power SW or AC plug-in.
MODEL MODEL MODEL MODEL
LC-32GA8EE LC-32BV8EE LC-37GA8EE LC-37BV8EE
LC-32GA8EF LC-32BV8EF LC-37GA8EF LC-37BV8EF
LC-32GA8EI LC-32BV8EI LC-37GA8EK LC-37BV8EK
LC-32GA8EK LC-32BV8EK LC-37GA8RU LC-37BV8RU
