Автор Тема: SP062700X  (Прочитано 432 раз)
SP062700X
« : 21 Октября 2020, 19:01:24 »
IRIS Symptom Code: ---- IRIS Section: ----
A B C D
INTERCHANGEABLE From OLD to NEW From NEW to OLD NOT INTERCHANGEABLE
GENERAL
MODELS
SERIAL No.
INTERCHANGEABILITY
PARTS
SERVICING
Is possible that some TV sets, sometimes, don’t turn on due to a malfunction of VCTP IC. These
TV sets after several trials by AC Cord, turn on again.
Inspection:
The TV set doesn’t turn on due to there is no I2C bus activity, because VCTP has not been properly
initialized. In this state, it’s not possible to enter in Bootloader mode. The TV set has no picture,
no sound, no backlight and the Power Supply Unit is in standby mode.
Countermeasure
When some of the above TV Sets is called for service due to the described phenomenon, proceed
as follows.
-Check on screen the VCTP software version (see Figure 1 on page 2/5). In case it is lower to
Ver1.202 for P55 or Ver1.042 for P70, update the software Version (VCTP Software):
1. Update the required VCTP Software Version File above detailed or upper, depending on the model.
1.1. Select the inches TV Set at “QS Temperature NVM Data Confi rmation Adjustment”.
1.2. Select the country TV Set at “Factory Settings adjustment”.
MODEL MODEL MODEL MODEL MODEL MODEL
LC26P55EE LC32P55EE LC37P55EE LC26P70EE LC32P70EE LC37P70EE
LC26P55EF LC32P55EF LC37P55EF LC26P70EF LC32P70EF LC37P70EF
LC26P55EI LC32P55EI LC37P55EI LC26P70EI LC32P70EI LC37P70EI
LC26P55EK LC32P55EK LC37P55EK LC26P70EK LC32P70EK LC37P70EK
LC26P55ERU LC32P55ERU LC37P55ERU LC26P70ERU LC32P70ERU LC37P70ERU
