Автор Тема: SP063000X  (Прочитано 427 раз)
SP063000X
« : 21 Октября 2020, 18:38:39 »
GENERAL
MODELS
SERIAL No.
INTERCHANGEABILITY
PARTS
SERVICING When some of the above TV set is called for service, proceed as follows:
Check if CN4 or CN5 connectors are broken.
1- If there are not connector broken, add four silicone bonds between FPC ferrite cores and
the backlight shield case.
2- If there are some connector broken, change the components as above table shows and add
four silicone bonds between the FPC ferrite cores and the backlight shield case.
See silicone bonds location in the figure 1 behind.
The FPC ferrite cores assembled on CN4 and CN5 may cause a breaking on the same CN4,
CN5 connectors and, the LCD controller unit may be made unsuitable.
MODEL MODEL MODEL MODEL
LC32P55EE LC37P55EE LC32P70EE LC37P70EE
LC32P55EF LC37P55EF LC32P70EF LC37P70EF
LC32P55EI LC37P55EI LC32P70EI LC37P70EI
LC32P55EK LC37P55EK LC32P70EK LC37P70EK
LC32P55ERU LC37P55ERU LC32P70ERU LC37P70ERU
