Автор Тема: SP070301X  (Прочитано 446 раз)
SP070301X
« : 21 Октября 2020, 18:26:46 »
IRIS Symptom Code: ---- IRIS Section: ----
A B C D
INTERCHANGEABLE From OLD to NEW From NEW to OLD NOT INTERCHANGEABLE
GENERAL
MODELS
SERIAL No.
INTERCHANGEABILITY
It is possible that in some of the below TV sets may appear a speaker vibration because the
foam strip are not correctly located and the speaker frame is in direct contact with the cabinet.
In order to solve this phenomenon proceed as is indicated below.
MODEL MODEL MODEL MODEL MODEL
LC-32GA8EE LC-32GA8EF LC-32GA8EI LC-32GA8EK LC-32GA8RU
LC-32BV8EE LC-32BV8EF LC-32BV8EI LC-32BV8EK LC-32BV8RU
LC-37GA8EE LC-37GA8EF LC-37GA8EI LC-37GA8EK LC-37GA8RU
LC-37BV8EE LC-37BV8EF LC-37BV8EI LC-37BV8EK LC-37BV8RU
LC-32GD8EE LC-32GD8EF LC-32GD8EI LC-32GD8EK LC-32GD8ERU
LC-32BT8EE LC-32BT8EF LC-32BT8EI LC-32BT8EK LC-32BT8ERU
LC-37GD8EE LC-37GD8EF LC-37GD8EI LC-37GD8EK LC-37GD8ERU
LC-37BT8EE LC-37BT8EF LC-37BT8EI LC-37BT8EK LC-37BT8ERU
