Автор Тема: SP072400X  (Прочитано 421 раз)
SP072400X
« : 21 Октября 2020, 17:25:30 »
IRIS Symptom Code: ---- IRIS Section: ----
1
A B C D
INTERCHANGEABLE From OLD to NEW From NEW to OLD NOT INTERCHANGEABLE
GENERAL
MODELS
SERIAL No.
INTERCHANGEABILITY
PARTS
SERVICING
REF No. NEW PARTS
DESCRIPTION
OLD PARTS
DESCRIPTION
PARTS
NUMBER
INTERCHANGEAB.
EFFECTIVE
FROM
EX
CODE
SN
CODE
VGC
Software
Version File
(IC3002)
46_52xd1_v235 Any previous - B Jun / 07 -- --
When some of the above TV is called for service due to the phenomenon described, proceed
to modify the set as follows:
- Check on screen the VGC (Main) Software Version. In case it was V2.34 Version or lower,
proceed to update this by V2.35 Version or upper:
Update the VGC software (Main PWB) using the fi le “46_52xd1_v235.img” or upper, and following
the own Service Manual (See 5-1 of 46/52XD1E Service Manual No. S76V5LC46XD1E).
When “loudness” is switched on in Sound menu, it works immediately (volume presetting to 13).
But as soon the channel is changed, it can be heard that loudness has been deactivated until the
the volume has been increased up to 15 (or higher). Then it can be appreciated that loudness has
been switched on again. Now it can be decreased the volume under 15, loudness works fi ne until
the channel is changed once more.
MODEL MODEL MODEL MODEL MODEL
LC-46XD1EE LC-46XD1EF LC-46XD1EI LC-46XD1EK LC-46XD1ERU
LC-52XD1EE LC-52XD1EF LC-52XD1EI LC-52XD1EK LC-52XD1ERU
