Автор Тема: SP111100X  (Прочитано 330 раз)
SP111100X
« : 21 Октября 2020, 15:13:23 »
IRIS Symptom Code: ---- IRIS Section: ----
WIRES SPEAKERS DAMAGED WHEN ASSEMBLED IN WALL.
In case the TV set is called for Service due to the above phenomenon, replace the wire as detailed
in the following pages:
Page 2 / 3: Procedure for 32LE210Ex Series.
Page 3 / 3: Procedure for 32LE210EBx and 32LE220EBx Series.
ATTENTION: In case the TV set has been serviced for any other reason, before be closed,
follow up descriptions behind, with special attention to separate cables from the
pillars area, where the rear cabinet will be assembled.
A B C D
INTERCHANGEABLE From OLD to NEW From NEW to OLD NOT INTERCHANGEABLE
GENERAL
MODELS
SERIAL No.
INTERCHANGEABILITY
PARTS
In some of the below models, it may appear TV sets with the speaker wire damaged (SP wire.)
SERVICING
REF No. NEW PARTS
DESCRIPTION
OLD PARTS
DESCRIPTION
PARTS NUMBER
INTERCHANGEAB.
EFFECTIVE
FROM
EX
CODE
SN
CODE
MODEL MODEL MODEL MODEL MODEL MODEL
LC-32LE210EE LC-32LE210EV LC-32LE210EK LC-32LE210RU LC-32LE210EBE LC-32LE210EBV
LC-32LE210EBK LC-32LE220EBE LC-32LE220EBV LC-32LB220EBE LC-32LB220EBV LC-32LS220EBV
