Автор Тема: SP113700X  (Прочитано 358 раз)
SP113700X
« : 21 Октября 2020, 15:12:25 »
IRIS Symptom Code: ---- IRIS Section: ----
ALTERNATIVE LCD PANEL MODULE
GENERAL
MODELS
SERIAL No.
Please fi nd below the details to replace the LCD Panel Module for an alternative one.
Procedure:
1.- Replace the panel as in the above table depending on the available LCD Panel Module. Both
panels are interchangeable, for each LCD Panel Module size.
2.- Update the software to version “V0.10.83.0” or upper according to the Service Manual.
Note that the software is common in all cases.
3.- Modify the Option code according to the proper table (behind.)
3.1.- Enter the Service Mode. SAM mode: Press keys “062596” followed by “OK” button.
3.2.- Select “Option Numbers”.
3.3.- Select “Group 1” to introduce options codes 1-4 (See tables behind.)
3.4.- Select “Group 2” to introduce options codes 5-9 (See tables behind.)
3.5.- Select “Store” and press “OK” button.
3.6.- Reboot the TV set and check the proper working.
A B C D
INTERCHANGEABLE From OLD to NEW From NEW to OLD NOT INTERCHANGEABLE
INTERCHANGEABILITY
PARTS
SERVICING
REF No. PARTS NUMBER
(Original)
PRICE
CODE
PARTS NUMBER
(VE)
PRICE
CODE
EFFECTIVE
FROM
INTERCHANGEAB.
32” LCD Panel Mod. R1LK315D3LA63Y -- R1LK315D3LA63F -- Aug/2011 A
40” LCD Panel Mod. R1LK400D3LB43Y -- R1LK400D3LB43F -- Aug/2011 A
46” LCD Panel Mod. R1LK460D3LB33Y -- R1LK460D3LB33F -- Aug/2011 A
MODEL MODEL MODEL MODEL MODEL MODEL
LC-32LE630E LC-40LE630E LC-46LE630E LC-32LE630RU LC-40LE630RU LC-46LE630RU
LC-32LE631E LC-40LE631E LC-46LE631E LC-32LE632E LC-40LE632E LC-46LE632E
LC-32LU630E LC-40LU630E LC-46LU630E LC-32LU632E LC-40LU632E LC-32LX630E
LC-40LX630E LC-46LX630E LC-32LX632E LC-40LX632E -
