Автор Тема: SP133800X  (Прочитано 353 раз)
SP133800X
« : 21 Октября 2020, 15:06:50 »
Objective:
TV can be controlled from the PC using Ethernet or Wifi connection. The input signal can be selected,
volume can be adjusted, switch off/on (*) TV set and various others adjustments and settings can be made.
Application:
LE750/ LE751/ LE752/ LE650/ LE651/ LE652 series
Procedure:
To setup IP-Control:
- Connect TV and PC to the same network (Ethernet or Wifi)
- Use Android emulator program for PC (lets you run apps from your phone on your PC)
- Install “Sharp Smart Remote +” App for Android.
Available to dowload from:
https://play.google.com/store/apps/details?id=de.discvision.remotecontrol&hl=es
Example of emulator used: BlueStacks App Player
This is a free software compatible with Windows (XP, Vista, WIN7/8) and Mac.
You can download from: http://www.bluestacks.com/
How to use it:
- Donwload .exe file and install.
- Search for “Sharp Smart Remote +” App and install:
Sharp Smart Remote + App download:
