Автор Тема: SP133900X  (Прочитано 465 раз)
SP133900X
« : 21 Октября 2020, 15:05:53 »
Service Information
Sharp Electronics (Europe) Limited Engineering Dept.
4
Objective:
Sharp SmartRemote + application can be used to control the Sharp AQUOS SmartTV over the mobile
devices.
By using the properties of the mobile devices such as touch screen and motion sensors,
Sharp SmartRemote + application offers a more comfortable, convenient and improved way to control the
Smart TV.
Application:
LE750/ LE751/ LE752/ LE650/ LE651/ LE652 series
Procedure:
App for Android devices:
● Search for “Sharp Smart Remote +” App in “Play Store” or , to be downloaded from :
https://play.google.com/store/apps/details?id=de.discvision.remotecontrol&hl=es
● Install app
● Open app, it will search automatically for the TV set.
Note: TV set must be connected to the same network as smartphone or tablet device.
If App is showing following message: “No TV connected. Do you want to search for TV now?”:
● Go to Settings and click in “Search for a TV”.
● If TV is still not found, then setup IP manually (To know TV IP address go to:
Menu → Setup → Multimedia/Network → Network settings → Networking)
 Mobile App
“Sharp Smart Remote Control +” app lets you operate SHARP AQUOS flat screen TV’s with your App for Android devices:
 Search for “Sharp Smart Remote +” App in “Play Store” or , to be downloaded https://play.google.com/store/apps/details?id=de.discvision.remotecontrol&hl=es
 Install app
 Open app, it will search automatically for the TV set.
Note: TV set should be connected to the same network as smartphone or tablet device
 Go to Settings and click in “Search for a TV”
 If TV is still not found, then setup IP manually
