Автор Тема: LV-754  (Прочитано 447 раз)
LV-754
« : 21 Октября 2020, 12:49:21 »
Subject CHANGE IN THE POWER UNIT
Model LC-70LE835E
LC-70LE835RU
LC-70LE836E
LC-70LE836S
LC-70LE838E
General
Description
Details of the
change
We inform you about a change in the power unit for performance improvement.
If the ceramic capacitor C7817/C7818 in the power unit becomes defective, the power of TV set does not
turn on (in this case, the Center Icon flashes twice). To prevent this from occurring, the following component
parts change in the power unit is implemented.
For further increasing the margin of the ceramic capacitors C7817/C7818, they are changed from 1000pF/1kV to
470pF/1kV type. With this change, the ferrite beads FB7803/FB7805 are also changed to the jumper to avoid a
noise due to the decline of the capacity of the C7817/C7818.
Servicing There is no change of Parts code of the power unit. Please supply and use the OLD power unit first.
For the details of change in the NEW power unit, please refer to the next page of this technical report.
Parts Ref.
No.
Description
Parts code InterchangeOLD
Q’ty NEW Q’ty ability
PRINTED WIRING BOARD ASSEMBLIES
- POWER Unit
RDENCA451WJQZ
(C7817/C7818: 1000pF/1kV)
(FB7803/FB7805: Ferrite beads)
(With No marking)
1
Same as OLD
(C7817/C7818: 470pF/1kV)
(FB7803/FB7805: Jumper)
(With one square marking)
1 A
Interchangeability
A: Completely interchangeable
D: Not interchangeable
