Автор Тема: LV-710  (Прочитано 335 раз)
LV-710
« : 21 Октября 2020, 11:50:29 »
Subject CORRECTION OF THE PARTS LIST FOR LCD PANEL MODULE
Model LC-60LE822E/ERU
General
Reason
We inform you of correction of the parts list for LCD panel module in the Service Manual of the publication No.
S90L660LE822E.
Each correct parts code which are used from the 1st production for reducing a rubbing of the Light guide plate to
the edge of emboss of Backlight chassis were not reflected in the parts list.
Servicing Please order or supply the correct parts code as shown in the below parts table.
If the Light guide plate rubs to the edge of the embossing of the Backlight chassis due to various external impacts
or stresses during transportation, the back of the Reflection sheet may be scratched and a white bright spot may
become visible at around the four corners of screen. If a white bright spot is found at around the four corners of
screen due to the above mentioned scratched reflection sheet, please replace the reflection sheet with the
correct parts code for repair.
For the details, please follow the attached procedure of this technical report.
Parts Ref
No.
Description
Parts code InterchangeWRONG
Q’ty CORRECT Q’ty ability
1 LCD PANEL MODULE UNIT R1LK600D3LW20Z
5 P Chassis Unit (Top) CHLDZ4423TP01 1 CHLDZ4423TP02 1 -
6 P Chassis Unit (Bottom) CHLDZ4424TP01 1 CHLDZ4424TP02 1 -
7 P Chassis Unit (SIDE) CHLDZ4425TP01 2 CHLDZ4425TP02 2 -
21 Back Light Chassis Unit CCHSM0106TP01 1 CCHSM0106TP02 1 -
12
Reflection sheet
PREFL2900TPZZ 1
PREFL3286TPZZ
