Автор Тема: LV-685  (Прочитано 471 раз)
LV-685
« : 21 Октября 2020, 11:17:00 »
Subject MAIN SOFTWARE UPDATE - VERSION MAIN 1.11
Model LC-32LE244E
LC-32LE144E/E(B)
General We inform you of the main software update to version 1.11.
The following is a list of changes in this release.
• Conformed to the digital broadcasting authentication standards (CableReadyHD/ComHem/Stofa/Boxer).
Servicing If the current software version in the unit is lower than 1.11, please update the main software of the unit with the
following order of priority.
1. Recommend customer to download the update file from your customer support web site.
2. Send the update file to customer from your service dept.
3. Update the unit by your service dept.
Main software update file to version 1.11: xx_LEx44_111_REV00.bin (4,052KB)
Note:
• The service list will be deleted after updating the main software. Please follow the attached instructions of this
technical report.
• When updating the unit by your service dept, record the confirmed symptom of the unit and the software version
before updating of the unit, and then record the software version after updating of the unit also.
Parts Ref. Parts code
No.
Description
OLD Q’ty NEW Q’ty
Interchangeability
- Main software Ver. 1.05 - Ver. 1.11 - C
Interchangeability
A: Completely interchangeable
D: Not interchangeable
Production
change
From February 2013 production as Running Change
