Автор Тема: LV-681  (Прочитано 383 раз)
LV-681
« : 21 Октября 2020, 11:13:50 »
Subject ADDITION OF SPACER ON THE POWER UNIT
Model Serial Number
Model name
OLD NEW
LC-70LE743E 204011112 ~ 209011552 209011553 ~
LC-70LE741E 204011112 ~ 210012470 210012471 ~
LC-70LE741S 205011112 ~ 210013078 210013079 ~
LC-70LE740E 203011112 ~ 210018666 210018667 ~
LC-70LE740RU 204011112 ~ 209012015 209012016 ~
General
Symptom
Cause
Countermeasure
Spacer is added to the Power unit for prevention of the following symptom.
A part of the Back cabinet of the TV set is deformed.
If the diode D7805 on the Power unit becomes defective (short-circuit), the heat sink of the Power unit will
become a high temperature. This may cause the Back cabinet to deform.
In order to give clearance between the Back cabinet and the Power unit, the 3(three) pcs of Spacer
LHLDZB650WJKZ should be added to SP7001, SP7002 and SP7004 on the Power unit.
Servicing When any of the TV sets which are within the OLD Serial Number range is required for service regardless of
the defect symptom, please perform the following procedures at the same time of servicing.
1. Add the 3(three) Spacer LHLDZB650WJKZ to SP7001, SP7002 and SP7004 on the Power unit.
2. Check for the Diode D7805 on the Power unit by using a tester. If it is defective, replace the Power unit to a
new one.
For how to add the Spacers, please follow the next page of this technical report.
Parts Ref. Parts code
No.
Description
OLD Q’ty NEW Q’ty
Interchangeability
RUNTKA933WJN1 (POWER Unit)
SP7001
SP7002
SP7004
Spacer - - LHLDZB650WJKZ 3 C
Interchangeability
A: Completely interchangeable
D: Not interchangeable
