Автор Тема: LV-650  (Прочитано 426 раз)
LV-650
« : 21 Октября 2020, 11:08:06 »
Subject SPECIFIC VERTICAL LINE ON THE SCREEN
Models
TV factory Inch size TV model name LCD Panel Module Unit
LC-70LE835E/RU
70 LC-70LE836E/S
LC-70LE838E
R1LK695D3GW2AX
LC-60LE830E/RU
LC-60LE831E/S
LC-60LE833E
R1LK600D3GW40H
LC-60LE635E/RU
LC-60LE636E/S
LC-60LE638E
R1LK600D3GW7CH
LC-60LE830EB/RUB
LC-60LE831EB/SB
60
LC-60LE833EB
R1LK600D3GW4BH
LC-52LE830E/RU
52 LC-52LE831E/S
LC-52LE833E
R1LK520D3GW40P
LC-46LE830E/RU
LC-46LE831E/S
LC-46LE833E
R1LK460D3GW40Y
LC-46LE830EB/RUB
LC-46LE831EB/SB
46
LC-46LE833EB
R1LK460D3GW4BY
LC-40LE830E/RU
LC-40LE831E/S
LC-40LE833E
R1LK400D3GW50Y
LC-40LE830EB/RUB
LC-40LE831EB/SB
SMPL
40
LC-40LE833EB
R1LK400D3GW5BY
General
Symptom
A problem that the specific vertical line defect symptom on the LCD module was reported from the field.
We inform you of the details and for how to handle this defect as follows.
The specific vertical line is when the following vertical line symptoms due to LCD panel leak defect can be
observed on the screen.
1. S-G leak
A cross line occurs, and a vertical line is a bright line.
