Автор Тема: LV-649  (Прочитано 396 раз)
LV-649
« : 21 Октября 2020, 11:07:09 »
PRECAUTION WHEN REPAIR LCD MODULE UNIT WITH LED-PWB FAILURE
Model Model LCD Panel Module Unit LED-PWB
LC-60LE822E
LC-60LE822ERU
R1LK600D3LW20Z
RUNTK4458TPZZ
RUNTK4459TPZZ
General
Symptom
Cause
We inform you of the following precaution when you repair the LCD module unit with the LED PWB failure.
LED backlight does not light on
In the LCD module assembly production line, the LED backlight on LED PWB becomes damaged when the Light
Guide Plate hits the left and right LED backlight when inserted the Light Guide Plate to the LCD module unit.
Servicing The LED package is very weak against any external shock.
When you repair the LCD module unit due to the LED PWB failure, please be careful so that the Light Guide
Plate does not touch the left and right LED backlight on LED PWB when you insert the Light Guide Plate to the
LCD module unit after replacing the defective LED PWB.
For how to insert it, please follow the attached instruction sheet of this technical report.
Parts Ref. Parts code
No.
Description
OLD Q’ty NEW Q’ty
Interchangeability
LCD PANEL MODULE UNIT
16 LED-PWB A RUNTK4458TPZZ 4 Same as OLD 4 -
17 LED-PWB B RUNTK4459TPZZ 4 Same as OLD 4 -
For details, refer to the LCD Module Edition of Service Manual (No. S90L660LE822E).
