Автор Тема: LV-632  (Прочитано 381 раз)
LV-632
« : 21 Октября 2020, 10:58:07 »
Subject MAIN SOFTWARE UPDATE - VERSION MAIN 1.18 [118E1207101]
Model LC-60/52/46/40LE822E
LC-60/52/46/40LE822ERU
LC-46/40LU822E
General We inform you of the main software update to version 1.18.
The following is a list of fixed issues in this release.
1. Black screen may be displayed at the time of Timeshift playback of H264 HD contents.
2. Sound is interrupted when DD+ sound is heard by optical output.
3. Some service may not be registered by search in TurkSAT satellite broadcasting.
4. Scramble may not be removed when TV set is started with CAM inserted.
5. E203 error is displayed when Cyfra+Satelite CAM / TurkSAT CAM is inserted.
6. Scramble is not removed when CAM of SMIT is plugged in and out.
7. Operation speed becomes slow when watching TurkSAT broadcasting.
Servicing If the current software version in the unit is lower than 1.18 [118E1207101], please update the main software of
the unit with the following priority.
1) Recommend customer to download the update file from your customer support web site and perform
software update by customer.
2) Send the update file to customer and perform software update by customer.
3) Update the unit by your service dept.
Main software update file to version 1.18: ODSSEL822A118.UVP
Note:
• When updating the unit by your service dept, record the confirmed symptom of the unit and the software
