Автор Тема: LV-619  (Прочитано 472 раз)
LV-619
« : 21 Октября 2020, 10:54:53 »
Subject MAIN SOFTWARE UPDATE - VERSION MAIN 3.00 [300E1206141]
Model LC-60LE636E/E(B)
LC-60LE636S/S(B)
General We inform you of the main software update to version 3.00.
1. Added the Favorite function.
2. Conformed to Riks TV (in Norwegian digital terrestrial broadcasting).
3. Fixed so that an automatic search of Target Region works normally in UK.
4. Fixed the judder which may occur when the specific video signal is input.
5. Fixed the malfunction of de-judder which may occur in specific contents.
Servicing If the current software version in the unit is lower than 3.00 [300E1206141], please update the main software of
the unit only by USB media with the following priority.
1) Recommend customer to download the update file from your customer support web site and perform
software update by customer.
2) Send the update file to customer and perform software update by customer.
3) Update the unit by your service dept.
Main software update file to version 3.00: CDIZ_LE636E_300.UVP
Note:
• When customer updates the main software to version 3.00 or more, the customized service lists will be erased
without any cautions. So, customer needs to install service again to receive it after updating the main software.
• Network update must not be used for software updating. Please do not put any software for the above model
on the server that is used as “Network update”.
• When updating the unit by your service dept, record the confirmed symptom of the unit and the software
Parts Ref Parts code
No.
Description
OLD Q’ty NEW Q’ty
Interchangeability
