Автор Тема: LV-616  (Прочитано 441 раз)
LV-616
« : 21 Октября 2020, 10:53:54 »
Subject MAIN SOFTWARE UPDATE - VERSION MAIN 3.00 [300E1206091]
Model LC-70LE835E
LC-70LE835RU
General We inform you of the main software update to version 3.00.
1. Added the Favorite function.
2. Fixed so that a scramble can be removed normally when TV set is turned on after CAM is inserted.
3. Fixed the malfunction of de-judder which may occur in specific contents.
4. Fixed the judder which may occur when the specific video signal is input.
5. Fixed the horizontal stripes which appear in image when the setting of “Scanning backlight 200” is switched to
“Scan”.
Servicing If the current software version in the unit is lower than 3.00 [300E1206091], please update the main software of
the unit with the following priority.
1) Recommend customer to download the update file from your customer support web site and perform
software update by customer.
2) Send the update file to customer and perform software update by customer.
3) Update the unit by your service dept.
Main software update file to version 3.00: CDIZ_LE835E_300.UVP
Note:
• When updating the unit by your service dept, record the confirmed symptom of the unit and the software
Parts Ref Parts code
No.
Description
OLD Q’ty NEW Q’ty
Interchangeability
- Main software All lower version - 3.00 [300E1206091] - C
Interchangeability
A: Completely interchangeable
C: NEW parts can be used in place of OLD parts
