Автор Тема: LV-605  (Прочитано 429 раз)
LV-605
« : 21 Октября 2020, 10:51:31 »
Subject MAIN SOFTWARE UPDATE – VERSION MAIN 3.01 [301E1206111]
Model LC-70LE740E/RU
LC-60LE740E/E(B)/RU/RU(B)
General We inform you of the main software update to version 3.01.
1. Added Favorite function.
2. Improved lamp error which may occur when the power is turned OFF and ON by Remote controller.
3. Reduced flicker at the time of 3D.
4. Fixed sort table of DVB-T/DVB-C/DVB-S when the country setting is Germany/Austria/Swiss.
5. Added subtitle display of the external file in USB movie.
6. Fixed so that a Satellite network watched at the last is displayed when SAT key is pushed during external
application (USB, DLNA, NET and so on).
7. Fixed so that a black screen is not displayed when a Home menu is displayed and removed during watching
CI+ broadcasting.
8. Invalidated Timeshift+ function when the country setting is Netherlands.
9. Added Zigg logo to Feature demo.
Servicing If the current software version in the unit is lower than 3.01 [301E1206111], please update the main software of
the unit with the following priority.
1) Recommend customer to download the update file from your customer support web site and perform
software update by customer.
2) Send the update file to customer and perform software update by customer.
3) Update the unit by your service dept.
Main software update file to version 3.01: CDZR_LE740E_301.UVP
Note:
• When updating the unit by your service dept, record the confirmed symptom of the unit and the software
