Автор Тема: LV-600  (Прочитано 412 раз)
LV-600
« : 21 Октября 2020, 10:50:40 »
Subject MAIN SOFTWARE UPDATE – VERSION MAIN 1.13 [113E1205111]
Model LC-60/46LE925E
LC-60/46LE925RU
General We inform you of the main software update to version 1.13.
1. Fixed the black screen which may occur at the time of the Timeshift playback of HD contents of H264.
2. Conformed to DVB-T standard of France (Canal Ready).
3. Fixed the interruption of audio which occurs at the time of the optical output of the DD+ audio.
4. Fixed so that a service can be registered normally by the channel search in TrukSAT broadcasting.
5. Fixed so that a scramble can be removed when TV set is turned on after CAM is inserted.
6. Fixed the error “E203” which occurs when the specific CAM (Cyfra+ Satelite and TrukSAT) are inserted.
7. Fixed so that a scramble can be removed when the CAM of SMIT is removed and inserted.
8. Improved the operation speed during watching TrukSAT broadcasting.
Servicing If the current software version in the unit is lower than 1.13 [113E1205111], please update the main software of
the unit with the following priority.
1) Recommend customer to download the update file from your customer support web site and perform
software update by customer.
2) Send the update file to customer and perform software update by customer.
3) Update the unit by your service dept.
Main software update file to version 1.13: SFIAEL925A113.UVP
Note:
• When updating the unit by your service dept, record the confirmed symptom of the unit and the software
Parts Ref Parts code
No.
Description
OLD Q’ty NEW Q’ty
Interchangeability
- Main software All lower version - 1.13 [113E1205111] - C
Interchangeability
A: Completely interchangeable
D: Not interchangeable
