Автор Тема: LV-587  (Прочитано 510 раз)
LV-587
« : 21 Октября 2020, 10:44:10 »
Subject MAIN SOFTWARE UPDATE – VERSION MAIN 2.08 [208E1204111]
Model LC-60LE830E/E(B)/RU/RU(B)
LC-52LE830E/E(B)/E(D)/RU/RU(B)/RU(D)
LC-46LE830E/E(A)/E(B)/E(C)/E(D)/RU/RU(A)/RU(B)/RU(C)/RU(D)
LC-40LE830E/E(A)/E(B)/E(C)/RU/RU(A)/RU(B)/RU(C)
General We inform you of the main software update to version 2.08.
1. Fixed so that a service can be registered normally by the channel search in TrukSat satellite broadcasting.
2. Fixed so that a scramble can be removed when TV set is turned on after CAM is inserted.
3. Added the automatic clear process of lamp error count.
Note: When the unit is started by the specific operation (CH DOWN + VOL UP + AC on),
the lamp error count isn't cleared.
Servicing If the current software version in the unit is lower than 2.08 [208E1204111], please update the main software of
the unit with the following priority.
1) Recommend customer to download the update file from your customer support web site and perform
software update by customer.
2) Send the update file to customer and perform software update by customer.
3) Update the unit by your service dept.
Main software update file to version 2.08: CDIZ_LE830E_208.UVP
Note:
• When updating the unit by your service dept, record the confirmed symptom of the unit and the software
Parts Ref Parts code
No.
Description
OLD Q’ty NEW Q’ty
Interchangeability
