Автор Тема: LV-576  (Прочитано 348 раз)
LV-576
« : 21 Октября 2020, 10:42:59 »
Subject SOLDER EXFOLIATION OF LED-PWB CONNECTOR
Model Serial Number
Model LCD Panel Module Unit
OLD NEW
LC-32LE630E 105011112 ~ 108027754 108027755 ~
LC-32LE630RU - ~ - 1st production ~
LC-32LE631E - ~ - 1st production ~
LC-32LE632E 105011112 ~ 108015124 108015125 ~
LC-32LU630E 107011112 ~ 108013100 108013101 ~
LC-32LX630E 107011112 ~ 108012839 108012840 ~
LC-32LU632E 108011112 ~ 108012349 109012350 ~
LC-32LX632E
R1LK315D3LA63Y/Q
108011112 ~ 108012228 108012229 ~
General
Symptom
Cause
We inform you of servicing procedure.
The backlight is not turned on.
Solder exfoliation at the solder area of the LED-PWB connector.
Servicing When the above mentioned problem is found, please perform additional soldering to the soldering area of the
LED-PWB connector as shown in the next pages instruction of this technical report.
Parts Ref Parts code
No.
Description
OLD Q’ty NEW Q’ty
Interchangeability
Interchangeability
A: Completely interchangeable
D: Not interchangeable
