Автор Тема: LV-556  (Прочитано 335 раз)
LV-556
« : 21 Октября 2020, 10:37:36 »
Subject ADJUSTMENT PROCEDURE FOR YELLOWISH PICTURE
Model LC-65XS1E
General We inform you of the adjustment procedure for the following yellowish picture phenomenon which may appear at
the center area of the screen when the unit has been used for a long period of time such as a monitor.
Yellowish picture appears at the center of the screen.
(White test pattern in the service mode)
Servicing Only when the above mentioned phenomenon has appeared on the screen, please perform the following
adjustment procedure. (Note: Do not apply the following picture adjustment procedure to any units which does
not have this phenomenon.)
Picture adjustment procedure:
1. Please update the LED micon software to the version 1.0.8.
(1) Copy the update file “SHOWLED_108_101007.USB” into the root directly of the USB memory device.
(2) Unplug the AC code from the unit.
(3) Insert the USB memory device to the USB port of the unit.
(4) While pressing “POWER + MENU” keys, plug the AC code to the unit
(5) Release the "POWER + MENU" keys after 3 seconds.
(6) After a while, the update will begin and "SYSTEM UPDATE" message will appear on the LCD.
While in the update, the LED back light does not turn ON. See the message by direct sunlight and so on.
(7) After that, the "UPDATE success" message will appear on the LCD.
(8) Unplug the AC code of the unit and remove the USB memory device from the unit.
2. Perform the “Picture maintenance” from the menu “Setup-Identification“.
Follow the “Picture maintenance” in the appendix of the operation manual
