Автор Тема: LV-507  (Прочитано 402 раз)
LV-507
« : 21 Октября 2020, 10:26:00 »
Subject BACKLIGHT LAMP FAILURE
Model
Model
Applicable
Serial number
LC-32D44E-BK 803011112 ~
LC-32D44E-GY 803011112 ~
LC-32D44RU-BK 803011112 ~
LC-32D44RU-GY 803011112 ~
LC-32D44S-BK 803011112 ~
LC-32D44S-GY 803011112 ~
General
Symptom
Cause
We inform you of servicing procedure when you replace the backlight lamp due to the backlight
failure.
No backlight and Lamp protector is activated.
Defective backlight lamp
Servicing When you repair the TV set due to the backlight defect, even if only one backlight lamp is defect, please
replace all the backlight lamps (10 pcs) at the same time.
Parts Ref Parts code
No.
Description
OLD Q’ty NEW Q’ty
Interchangeability
LCD PANEL UNIT (R1LK315T3GW30Y/ R1LK315T3GW30Q)
- Backlight lamp RLMPLA029WJN1 10 RLMPLA029WJN1 10 E
Interchangeability
A: Completely interchangeable
D: Not interchangeable
