Автор Тема: LV-487  (Прочитано 398 раз)
LV-487
« : 21 Октября 2020, 10:16:56 »
Subject MAIN SOFTWARE UPDATE - VERSION MAIN 1.07 [ E1010291 ]
Model LC-60/46LE925E
LC-60/46LE925RU
General We inform you of the main software update to version 1.07.
For the list of fixes and changes, please refer to the next page of this technical report.
Servicing Only if customer complains of the fixed phenomena in this release, check for the current software version in the
unit. If it is lower version than 1.07 [E1010291], update the unit with the following priority.
Firstly: Recommend the customer to download the update file from your web site.
Recommend the customer to update the software through network.
(Update the unit by the customer)
Secondly: Send the update file to the customer. (Update the unit by the customer)
Thirdly: Update the unit by your service.
Main software file name: SFIAEL925A107.UVP (27MB)
Note:
• When updating unit by using a USB memory device, the user settings will be kept in the unit.
• For Net Update:
- Uploading to the server is necessary and it is carried out in SEEG.
- Dialog notice isn't given to the user.
