Автор Тема: LV-458  (Прочитано 387 раз)
LV-458
« : 21 Октября 2020, 10:13:40 »
Subject
MAIN SOFTWARE UPDATE - VERSION MAIN 1.06[E1008051]
Model LC-46/40LE812E/ERU
LC-46/40LX812E/ERU
General We inform you of the main software update to version 1.06.
The following is a list of specification changes in this release.
[Specification changes in version 1.06]
(1) For the country settings of “German”, “Austria” and “Switzerland”, the service data that is collected at the
top of service list when searching satellite broadcast (Preset data) was updated to the on-the-spot
specified data.
・ For the country settings of “German”, the preset data was updated because of old data.
・ For the country settings of “Austria” and “Switzerland”, the preset data was set in.
・ The services that don’t correspond to the preset data, service list is ordered alphabetically.
(2) For the country settings of “German”, “Austria” and “Switzerland”, the channel sort function for satellite
broadcast was changed from existing “Change” function to “Move” function that enables to insert the
arbitrary service to specific service number.
(3) On the search selection screen of 1stAI, the display of guidance that leads to the channel search of
satellite broadcast beside Digital/Analogue/Skip.
Servicing Only if the above mentioned specification change is required, please check the main software version of the
unit. If it is lower than the latest version 1.06[E1008051], update the unit with the following priority.
Firstly: Recommend the customer to download the update file from your web site. (Update the unit by
the customer)
Secondly: Send the update file to the customer. (Update the unit by the customer)
Thirdly: Update the unit by your service.
Main software file name: ODSSEL812A106.UVP (32.0MB)
Note:
・ When updating the unit by your service, record the confirmed symptom of the unit and both the current
software version (before updating) and the updated version (after updating).
・ When updating unit by using a USB memory device, the user settings will be kept in the unit.
