Автор Тема: LV-431  (Прочитано 398 раз)
LV-431
« : 21 Октября 2020, 10:03:57 »
Subject
MAIN SOFTWARE UPDATE - VERSION MAIN 1.22[E1004211]
Model LC-52/46/40/32LE700E/S/RU, LC-52/46/40/32LE700E(A)/S(A)/RU(A)
LC-46/40/32LU700E/S, LC-46/40/32LU700E(A)/S(A)
LC-46/40/32LX700E/RU, LC-46/40/32LX700E(A)/RU(A)
General We inform you of the main software update to version 1.22.
The following is a list of fixed phenomena in this release.
[ Fixed phenomena]
1. The discrimination for single or multiple sound isn’t determined and the setting keeps changing in Italian ATV
broadcast.
2. Sound is muted at the specific timing by the specific channel of Spanish DVB-T broadcast.
Servicing If customer complains of the above mentioned phenomenon, please check the main software version of the
unit. If it is lower than the latest version 1.22[E1004211], update the unit with the following priority.
Firstly: Recommend the customer to download the update file from your web site. (Update the unit by
the customer)
Secondly: Send the update file to the customer. (Update the unit by the customer)
Thirdly: Update the unit by your service.
Main software file name: PRHREEA122.UVP
Note:
・ When updating the unit by your service, record the confirmed symptom of the unit and both the current
software version (before updating) and the updated version (after updating).
・ When updating unit by using a USB memory device, the user settings will be kept in the unit.
