Автор Тема: LV-406  (Прочитано 452 раз)
LV-406
« : 21 Октября 2020, 10:02:21 »
Subject MAIN SOFTWARE UPDATE - VERSION 1.10 [ E0911191 ]
Model LC-52/46/42/32DH77E(C)/S(C)/RU(C)
General
We inform you of the main software update to version 1.10.
Main version
[Identification]
Phenomenon (Condition)
1.10
[E0911191]
• After selecting a specified service channels, the picture/audio is not output.
(Broadcasting in Italy)
• When selecting channels, the ATV Subtitle becomes ON mode.
(S series models and ATV)
• If the “Auto Volume” in the menu was set to “On”, when the power is turned on, the “Auto
Volume” setting will change to “Off”.
(“Auto Volume” setting “On”)
For the list of changes and fixes in the previous software version, please see the next page of this technical report.
Servicing
If customer complains of the above mentioned phenomena, check the main software version of the unit. If it is lower
than the latest version 1.10 [E0911191], update the unit according to the following priority.
Firstly: Recommend the customer to download the update file from your web site.
(Update the unit by the customer)
Secondly: Send the update file to the customer.
Thirdly: Update the unit by your service.
Main software file name: PRHAEUA110.UVP
Note:
• When updating the unit by your service, record the confirmed symptom of the unit and both the current software
version (before updating) and the updated version (after updating).
• When updating unit by using a USB memory device, the user settings will be kept in the unit.
