Автор Тема: LV-393  (Прочитано 423 раз)
LV-393
« : 21 Октября 2020, 10:00:11 »
Subject MAIN SOFTWARE UPDATE - VERSION 1.05 [ E0911141 ]
Model LC-52/46/40/32LE705E/S/RU
LC-46/40/32LX705E
LC-46/40/32LU705E/S
General
We inform you of the main software update to version 1.05.
The following is a list of changes and fixes in this release.
Main Version
[Identification]
Phenomenon (Region and/or Condition)
1.05
[E0911141]
• Operation of the unit may become slow with a specified DVB-C HD broadcasting. (DVB-C)
• Incompatible audio caution may be displayed while operating the HDMI equipment. (HDMI
device)
• Broadcasting signal that is out of standard of DVB (No NIT/Some NITa) can not be searched.
(DVB-C of Swiss and Germany)
• Each timing of audio output of both “SCART2” and “Audio Out” synchronizes with the video
of “Monitor Out” of SCART2, but they are earlier than the picture of the screen as the
specification. Added a menu item that can be selected “Menu-Option-Audio out delay”.
(“Audio Out” terminal output)
• The translation of Hungarian “HOME” is wrong. Modified the Hungarian to “OTTHONI”.
(Hungarian)
Servicing
If customer complains of the above mentioned phenomenon, please check the main software version of the unit.
If it is lower than the latest version 1.05 [E0911141], update the unit according to the following priority.
Firstly: Recommend the customer to download the update file from your web site. (Update the unit by the
customer)
Secondly: Send the update file to the customer. (Update the unit by the customer)
Thirdly: Update the unit by your service.
Main software file name: PRHCEEA105.UVP
Note:
・ When updating the unit by your service, record the confirmed symptom of the unit and both the current software
version (before updating) and the updated version (after updating).
・ When updating unit by using a USB memory device, the user settings will be kept in the unit.
