Автор Тема: LV-392  (Прочитано 412 раз)
LV-392
« : 21 Октября 2020, 09:58:50 »
Subject MAIN SOFTWARE UPDATE – VERSION 1.16 [ E0911041 ]
Model LC-52/46/40/32LE700E/S/RU
LC-52/46/40/32LE700E(A)/S(A)/RU(A)
LC-46/40/32LX700E/RU
LC-46/40/32LX700E(A)/RU(A)
LC-46/40/32LU700E/S
LC-46/40/32LU700E(A)/S(A)
General We inform you of the main software update to version 1.16.
The following is a list of changes and fixes in this release.
Main version
[Identification]
Phenomenon (Condition)
1.16
[E0911041]
・ When the power turns on, the [Auto Volume] on menu changes to set OFF, even though
it was set to ON before.
1.15
[E0910261]
・ After when selecting specified service channels, the picture/audio do not output.
(Broadcasting in Italy)
・ When selecting channels, the Subtitle becomes ON mode. (S models and ATV)
・ The translated language in the Home/Store selecting screen of the 1st Auto Installation
were incorrect mean.
INCORRECT: Storage CORRECT: Store
Servicing If customer complains of the above mentioned phenomenon, please check the main software version of the unit.
If it is lower than the latest version 1.16 [E0911041], update the unit according to the following priority.
Firstly: Recommend the customer to download the update file from your web site. (Update the unit by the
customer)
Secondly: Send the update file to the customer. (Update the unit by the customer)
Thirdly: Update the unit by your service.
Main software version Software file name (file size): PRHREEA116.UVP (32,769kB)
Note:
・ When updating the unit by your service, record the confirmed symptom of the unit and both the current software
version (before updating) and the updated version (after updating).
・ When updating unit by using a USB memory device, the user settings will be kept in the unit.
