Автор Тема: LV-388  (Прочитано 426 раз)
LV-388
« : 21 Октября 2020, 09:57:59 »
Subject SOFTWARE UPDATE - MAIN Ver.2.25.0/DIGITAL Ver.8.4.0
Model LC-52HD1E/RU
LC-46HD1E/RU
Symptom
We inform you of the software update to MAIN Ver.2.25.0/DIGITAL Ver.8.4.0
The following is the fixes in this release.
・As French terrestrial HD broadcasting station(TF1,France 2, M6) changed the audio signal standards from the
simultaneous broadcasting signal of both Dolby Digital and Dolby Digital Plus(DD+) to single broadcasting
signal of only Dolby Digital Plus(DD+), the TV set would not output sound in France.
Servicing When the TV set requires service, check the MAIN/ DIGITAL software version in the unit. If it is lower than the
following software version, please upgrade to MAIN Ver.2.25.0/DIGITAL Ver.8.4.0.
MAIN Ver.2.25.0 software file: HD1_V2.25.0_20090811.tli (5,109KB)
DIGITAL Ver.8.4.0 software file: HD1DVB_V8.4.0_20090806.tli (3,633KB)
Note:
・Record the actually confirmed symptom, both the current software version (before update) and the updated
software version (after update).
