Автор Тема: LV-380  (Прочитано 383 раз)
LV-380
« : 21 Октября 2020, 09:57:09 »
Subject MAIN SOFTWARE UPDATE – VERSION 1.14 [E0909161]
Model LC-52/46/40/32LE700E/S/RU
General We inform you of the main software update to version 1.14.
The following phenomena are solved in this release.
Main version
[ Display in the menu ]
Phenomenon
1.14
[E0909161]
When CAM is inserted and the last channel is DVB-C. E203 occurs at the time of
starting up.
1.13
[E0909041]
When Auto Sync function is performed with PC (D-sub) input, horizontal picture
position shifts.
Servicing When the unit requires service due to the above mentioned phenomena, please take the following steps.
1. Check the main software version of the unit.
2. If it is lower than the version 1.14, update the unit as following priority.
(First) Downloading the update file by a customer from your web site.
(Second) Sending a USB memory device (with the update file) to a customer.
(Third) Updating the unit by your service division.
Main software version Software file name (file size): PRHREEA114.UVP (32,769kB)
Note:
・ Record the confirmed symptom and both the current software version(before update) and the updated software
version(after update).
・ When updating unit by using a USB memory device, the user settings will be kept in the unit.
