Автор Тема: LV-368  (Прочитано 448 раз)
LV-368
« : 21 Октября 2020, 09:55:35 »
Subject MAIN SOFTWARE UPDATE – VERSION 1.10 [E090728HDE1]
Model LC-46/42/32DH77E/S/RU
General
We inform you of the main software update to version 1.10.
The following phenomena are solved in this release.
Main version Details (Area or condition)
1.10
[E090728HDE1]
• After selecting DTV, screen becomes freeze for about 10 seconds. (France)
1.09
[E090511HDE1]
• In some MHEG contents child display mutes in black. (U.K)
• Poor picture quality of MHEG static image data. (U.K)
• Some service is not registered when searching channels. (France)
• A registered service can not watched due to E203 error. (France)
• Channel viewing program from standby can not start on and after 2016 year.
(Reservation program on and after 2016 year)
• When searching channels in area which has over 16 frequencies with terrestrial digital
broadcasting, over 16 frequencies can not be registered. (Italy)
Servicing When the unit requires service with the above mentioned phenomenon, please take the following steps.
1. Check the main software version of the unit.
2. If it is lower than the version 1.10, update the unit as the following priority.
(First) Downloading the update file by a customer from your web site.
(Second) Sending a USB memory device (with the update file) to a customer.
(Third) Updating the unit by your service division.
Main software version
[ Display in the menu ]
Software file name
(file size)
MAIN: 1.10
[E090728HDE1]
Sharplcdmnceuhde110.img
(13,752kB)
When you update the unit by using a USB memory device, user settings’ information will be kept in the unit.
