Автор Тема: LV-346  (Прочитано 355 раз)
LV-346
« : 21 Октября 2020, 09:49:11 »
Subject PINCHED WIRE HARNESS (LB)
Model LC-42DH77E/S/RU
General There were cases that the LB-wire harness (QCNW-H853WJQZ) was pinched between the rib of the
cabinet-B and the VESA angles.
If the LB-wire harness was damaged, the unit may exhibit some phenomena below.
・ Inverter shuts down (indicator shows error)
・ Screen failure (bright and dark horizontal stripes appears when brightness is low or high)
Servicing When the unit requires service due to the above mentioned defect, replace the pinched LB-wire harness
(QCNW-H853WJQZ) with new one, and make sure that the LB-wire harness is dressed correctly.
Also when the unit requires service for other defect, visually check if the LB-wire harness check is pinched
by viewing from the grids of the back cabinet of the unit at the same time.
If the LB-wire harness is not pinched, it is not necessary to replace it with new one.
For how to work, follow the attached instruction sheet of this technical report.
Production
change
From May 2009 production onwards
