Автор Тема: LV-309  (Прочитано 405 раз)
LV-309
« : 21 Октября 2020, 00:20:33 »
Subject MAIN SOFTWARE UPDATE - VERSION 2.21.0
Model LC-52HD1E/RU
LC-46HD1E/RU
General
We inform you of the main software update to the version 2.21.0.
The following is the fixes in this release.
• Sometimes black screen is recorded when recording of DVB-T.
• Some file path is cut if the path and file name are too long in Photoviewer.
• System time jumps when HDMI or component input is selected.
• Some serial recordings are not performed.
• Up/Down is visible instead of empty AQUOS link character (E145).
• Cursor down hint disappears when OK key is pressed in Timer overview menu.
• If the system time (inside broadcasting signal) changes at the time of the beginning of the timer recording, the
timer recording is not performed even the start time of programmed timer recording has come.
Servicing If customer complains of the above mentioned issues, check the main software version in the unit. If it is 2.20.0 or
less, update the unit to the version 2.21.0.
Main software version File name (File size)
2.21.0 HD1_V2.21.0_20081016.tli (5,071KB)
For how to update the unit, refer to the service manual.
