Автор Тема: LV-308  (Прочитано 339 раз)
LV-308
« : 21 Октября 2020, 00:19:48 »
Subject MAIN SOFTWARE UPDATE - VERSION 1.25 [W0902121]
Model LC-65XS1U/E/RU/A/M/X
LC-52XS1U/E/RU/A/M/X
General
We inform you of the main software update to the version 1.25 [W0902121].
The following is the changes and fixes in this release.
• The LED lighting becomes disturbed at the time of the power on after 6 or 8 seconds after the power off.
• The LED-TCON data is lost when the Initialization to factory settings is performed after replacing the
LCD-TCON unit. The re-adjustment of the LCD -TCON data is required.
Servicing If customer complains of the above mentioned issues, check the current software version in the unit. If it is lower
than the version 1.25 [W0902121], update the unit by using a USB memory device with the update file.
Production
change
From December 2008 production
