Автор Тема: LV-307  (Прочитано 502 раз)
LV-307
« : 21 Октября 2020, 00:19:00 »
Subject MAIN SOFTWARE UPDATE – VERSION 1.24 [W0811101]
Model LC-65XS1U/E/RU/A/M/X
LC-52XS1U/E/RU/A/M/X
General
We inform you of the main software update to the version 1.24 [W0811101].
The following is the changes and fixes in this release.
• In the [Picture adjustments] - [Advanced] - [Colour Temp.] - [R Gain/G Gain/B Gain] menu, when the
gain adjustment setting value is changed for less, the color becomes strong.
• In HDMI input, when the picture is changed from 1080P/24Hz signal to wallpaper picture, the image
becomes disturbed.
• Poor wallpaper picture.
Servicing If customer complains of the above mentioned issues, check the current software version in the unit. If it is lower
than the version 1.24 [W0811101], update the unit by using a USB memory device with the update file.
Production
change
From December 2008 production
