Автор Тема: LV-294  (Прочитано 408 раз)
LV-294
« : 21 Октября 2020, 00:14:17 »
Subject BLOCK NOISE APPEARS WHEN CI CARD INSERTED
Model
LC-52/46/42/37/32X20E/S/RU
LC-52/46/42XL2E/S/RU
LC-46X8E/S/RU
LC-37/32XL8E/S/RU
KRV-46V/37V/32V
LC-42/37/32G20E/S
LC-42/37/32B20E/S
General
Block noise may appear in the screen when the set receives DTV broadcast signal with inserting CI card.
A possibility of being this symptom is high if the block noise appears when CI card is inserted during viewing free
broadcast signal and disappears when CI card is removed.
Servicing
Refer to
When the unit requires service with the above mentioned symptom, apply the following countermeasure to the main
unit as follows.
1) If the unit automatically reboots when CI card is inserted, eliminate R9154.
2) If the block noise appears in the screen, add IC4409 and eliminate R4410 (or cut pattern).
For how to modify the main unit, follow the modification instruction in the next page of this technical report.
Service Manual
Parts
Ref. Parts code
No. Description OLD Q’ty NEW Q’ty
*Interchangeability
Price
code
MAIN UNIT
IC4409 Buffer IC -- --- VHITC7SH17U-1Y 1 D AC
R4410 Resistor, 0 ohms VRS-CZ1JF000JY 1 --- --- D ---
R9154 Resistor, 2.2k ohms VRS-CZ1JF222JY 1 --- --- D ---
Interchangeability
A: Completely interchangeable
B: Interchangeable from OLD to NEW
C: Interchangeable from NEW to OLD
D: Not interchangeable
