Автор Тема: LV-282  (Прочитано 368 раз)
LV-282
« : 21 Октября 2020, 00:10:11 »
Subject ADDING PARTS FOR EDID DATA
Model Model name Serial number OLD NEW
Production
(Effective from)
LC-32D65E
LC-32D65RU
LC-37D65E
LC-37D65RU
LC-46D65E
LC-46D65RU
LC-52D65E
LC-52D65RU
LC-32DH65E
LC-32DH65S
LC-37DH65E
LC-37DH65S
LC-46DH65E
LC-46DH65S
LC-52DH65E
LC-52DH65S
LC-32D653E
LC-32D654E
LC-32DH66E
807∗11112 ~ 811∗∗∗∗∗∗
809∗11112 ~ 811∗∗∗∗∗∗
810∗11112 ~ 811∗∗∗∗∗∗
808∗11112 ~ 811∗∗∗∗∗∗
811∗11112 ~ 811∗∗∗∗∗∗
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
812∗∗∗∗∗∗ ~
SEES
(from Dec. 2008)
LC-37D65E
LC-37D65RU
LC-37DH65E
LC-37DH65S
LC-37D653E
LC-37D654E
LC-37DH66E
809011112~ 8110∗∗∗∗∗
811011112~ 8110∗∗∗∗∗
8120∗∗∗∗∗ ~
8120∗∗∗∗∗ ~
8120∗∗∗∗∗ ~
8120∗∗∗∗∗ ~
8120∗∗∗∗∗ ~
8120∗∗∗∗∗ ~
8120∗∗∗∗∗ ~
SMPL
(from Dec. 2008)
General
Since the unit does not support the “plug and play”, the unit will display the message “Out of range” because
the unit can not change picture resolution into a possible output range when an incompatible signal is input
to the unit.
We inform you that the EDID IC and peripheral parts have been added for change of specification so that
the unit can support the “plug and play”.
Servicing
Only if customer complains of this phenomenon, modify the unit.
(You do not need to modify the unit in case of customer’s complaint due to other phenomenon.)
