Автор Тема: LV-279  (Прочитано 439 раз)
LV-279
« : 21 Октября 2020, 00:09:15 »
Subject MAIN SOFTWARE UPDATE – VERSION 1.090
Model LC-32D44E/S/RU-BK/GY
General
We inform you of the main software update to version 1.090. The following is solved in this release.
• When the power of the unit is turned on/off repeatedly, the unit will be locked up with the LED indicator
lighting in red. The unit will become unable to restart/operate.
Servicing
Check the current software version in the unit.
If the software version is less than 1.090, update the software to version 1.090.
After update, make sure the software version is 1.090 in the unit.
For the details on how to upgrade, please refer to the Service Manual.
New main software version Software file name
1.090 32D44_V1090S.bin
Note:
With this software update, the user settings will be kept in the unit.
If you perform the delivery setting (Factory-Init), the user settings will be initialized.
Production
change
From March 2008, the software has been applied in production.
