Автор Тема: LV-272  (Прочитано 382 раз)
LV-272
« : 21 Октября 2020, 00:08:04 »
Subject POOR CONTACT OF HDMI CABLE
Model LC-37X20E/S/RU, LC-37B20E/S, LC-37G20E/S
LC-32X20E/S/RU, LC-32B20E/S, LC-32G20E/S
Symptom
Cause
When a HDMI cable is connected to the HDMI terminal, some picture/sound trouble may occur due to poor
contact of the HDMI cable.
When the terminal side of the rear cabinet expands about 1.0-1.5 mm by temperature, the connected HDMI
cable is pushed back and causes poor contact between the HDMI plug and the HDMI socket.
(This occurs depending on the type of the HDMI cable.)
Servicing If customer complains of this problem, remove the original screw in the EXT-4 HDMI terminal, and change it for
plastic screw (LX-BZA279WJKZ) and washer (XWHS730-05000) to fix the rear cabinet.
See page 2.
Parts
Parts code
Ref.
No.
Description
OLD NEW
Q’ty
*Interchangeability
Price
code
--- Screw for EXT-4 HDMI XBPS830P06000 LX-BZA279WJKZ 1 C AF
--- Washer --- XWHS730-05000 1 C AA
*Interchangeability
A: Completely interchangeable. OLD ↔ NEW C: Interchangeable from NEW to OLD. OLD ← NEW
B: Interchangeable from OLD to NEW. OLD → NEW D: Not interchangeable. OLD ≠ NEW
Production
change
From June 2008 production, the HDMI terminal hole on the rear cabinet is extended so that the HDMI cable is
not pushed back.
See page 3.
