Автор Тема: LV-260  (Прочитано 436 раз)
LV-260
« : 21 Октября 2020, 00:05:41 »
Subject INVERTER UNIT SHUTDOWN
Model Destination Model Name LCD Module Code
North America LC-32D41U
LC-32HT2U, LC-32M41U, LC-40C32U
R1LK315T3LF15
Europe LC-32SA1E/RU, LC-32SD1E/RU
LC-32GA8E/RU, LC-32GD8E/RU
LC-32BT8E/RU, LC-32BV8E/RU
R1LK315T3LF14
R1LK315T3LF15
Asia LC-32AW5X
LC-32AX5X, LC-32AX5H, LC-32AX5M
LC-32BD6X
LC-32BX5H, LC-32BX5M
LC-32BX6H, LC-32BX6M, LC-32BX6N
LCD-32AX5, LCD-32BX5, LCD-32BX6
R1LK315T3LF15
General If the screws fixing the inverter unit and inverter cover become loose, the inverter unit may shut down due
to bad contact of the grounding.
Symptom: After the poweron, the unit operates, but suddenly backlight shuts off. Audio stays normal.
Servicing When servicing any unit regardless of symptoms, please change all the 6 screws to the new screw with
washer LX-BZ2315TPZZ.
Parts Ref. Parts code
No. Description
OLD NEW
Q’ty
Interchangeability
Price
code
--- Screw with washer LX-BZ2090TPZZ LX-BZ2315TPZZ 6 C AC
Interchangeability
A: Completely interchangeable. OLD ↔ NEW C: Interchangeable from NEW to OLD. OLD ← NEW
B: Interchangeable from OLD to NEW. OLD → NEW D: Not interchangeable. OLD ≠ NEW
Production
Change
Applicable LCD panel module was already discontinued.
NEW PARTS:
LX-BZ2315TPZZ
M3 x 7mm
φ8 washer
Procedure:
Change the 6 screws to LX-BZ2315TPZZ.
